moment and force reaction for contact region in ansys mechanical
    • jehanzeb
      I am trying to add a force and moment reaction probe result in ansys Mechanical for contact region but it shows ? in the tree
      whether for boundary condition fixed support its ok and solve but when i choose contact region its not working showing ? mark in tree
      following the same method as explain
      https://www.padtinc.com/blog/using-probes-to-obtain-contact-forces-in-ansys-mechanical/
      but its not working for my case whats the possible reason and how i obtain moment and force reaction for contact region ?? please
      Thank you!
      Did you turn on Contact Miscellaneous under the Output Controls of the Analysis Settings?
      Contact Miscellaneous. Turn On if Contact Based Force Reactions are desired. The default value is No. Available for Static and Transient Structural analysis types. Not Available when linked to a Modal analysis.
    • jehanzeb
      not working, After Contact Miscellaneous. Turn On
      possible reason please
      Click Solve and read any messages that get written out to the message window.
    • EricRenner
      I had to turn on nodal forces and contact miscellaneous to get the force and moment reactions n
Viewing 4 reply threads
  • The topic ‘moment and force reaction for contact region in ansys mechanical’ is closed to new replies.
