April 8, 2024 at 8:58 am
vikram chahal
Subscriberi want to apply a moment around z axis of a partially filled tank at its base or CG, after compiling while i am hooking this UDF under dynamic mesh, In base as rigid body its showing incorrect CG motion(Assume No motion)
#include "udf.h"DEFINE_SDOF_PROPERTIES(tank_moment, prop, dt, time, dtime){  real t = CURRENT_TIME; // Obtain the current simulation time Â  prop[SDOF_LOAD_M_Z] = 0.0; // Initialize moment load to 0.0  if (t <= 2.0)  {  Â    prop[SDOF_LOAD_M_Z] = 5000.0; // Moment load in the z-direction  }  printf("\ntank_moment: updated SDOF properties");} -
April 17, 2024 at 9:50 am
SRP
Ansys EmployeeHi,
Since you are not seeing the intended motion, it may be beneficial to add additional debugging output to your UDF to track the CG's motion over time.
- The topic ‘moment along z axis at base or CG of water tank for 2 secs’ is closed to new replies.
1891
1419
