December 16, 2021 at 7:50 pm
Brian Maneval
SubscriberI have a part that a customer would like a cavity mold created from. I have the .stp file to create the mold cavity from. I need to know how to extrude the .stp file into a plate to create the mold.Â
December 17, 2021 at 5:14 am
Devendra Badgujar
Forum ModeratorHello Brian Maneval
Let me check this and get back to you on this.
December 17, 2021 at 8:32 am
Devendra Badgujar
Please can you send the file to me. I will try it on my end and update on that.Â
February 4, 2022 at 8:40 am
Devendra Badgujar
Forum ModeratorBrian Maneval Please can you update me on this, were you able to create this ?
February 22, 2022 at 8:29 pm
Brian Maneval
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hi Devendra
I apologize that I haven't responded back to you yet. I just now saw that you messaged me back.
I will attach the file I'm try to create the cavity from.
February 23, 2022 at 5:10 am
Devendra Badgujar
Forum ModeratorBrian ManevalÂ
Thanks for the file. I will check and get back to you.
February 23, 2022 at 6:42 am
Devendra Badgujar
Forum ModeratorHi Brian Maneval
Please can you also attach the .stp file that you would like to extrude into a plate to create the mold.
Regards.
February 23, 2022 at 2:58 pm
Brian Maneval
Devendra Badgujar Ill send it right over
Side b1 is one half of the moldÂ
side a will be the other side of the mold will need this one on a different plate
February 23, 2022 at 3:03 pm
Devendra Badgujar
Thanks for sharing the files. I will try it on my end and will update you.
Regards.
February 23, 2022 at 3:43 pm
Devendra Badgujar
Forum Moderator🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hi Brian Maneval
You will need to use combine tool to create mold cavity into the plate.Â
I have created a short video to demonstrate the process for you. Please check the attached file.Â
February 23, 2022 at 3:55 pm
Brian Maneval
SubscriberDevendra Badgujar Thank you so much that's exactly what I needed
- The topic ‘Mold from .stp file’ is closed to new replies.
4678
1565
1386
1241
