October 2, 2023 at 4:38 pm
Costas
SubscriberHello everyone.
Is there a possibility to include a hardening behaviour in a Mohr Coulomb model in Workbench?Â
Thanks,
Costas
October 3, 2023 at 12:31 pm
John Doyle
Ansys Employee -
October 3, 2023 at 1:02 pm
Costas
SubscriberHi John,
thanks for your reply. I've read that but my problem is that I don't know how to implement the hardening parameters. Is there a way I can do this in Workbench?
October 4, 2023 at 7:47 pm
John Doyle
Ansys EmployeeWe don't have a curve fitting tool in MAPDL for this model. You might be able to do something in an excel spreadsheet, if you have test data that characterizes stress and strain beyond yield. Excel has a solver add-on that enables you to derive parameters to minimize an expression. If you can write an expression for the residual (error), between the trial stress (based on the formula) and the experimental (based on test data), you might be able to optimize the value for each property by solving for the minimum residual. I have seen that done with other models. It would be an iterative process, solving for one parameter at a time, while holding the other constant. It is not a casual walk thru the park, but it could be done. There are other 3rd party tools (like MCALIBRATION developed by PolymerFEM) that might also be helpful.
October 6, 2023 at 2:55 pm
Costas
SubscriberMany thanks John.
I will try.
- The topic ‘Mohr Coulomb with hardening’ is closed to new replies.
5674
1890
1419
