May 1, 2019 at 6:30 pm
gorzillon
SubscriberIs it possible to modify Global Coordinate System in Ansys? I imported a model, and axis by default are not the most optimal.
Create a local coordinate system is not the best option in this case for me, because the material is orthotropic, so I'd like to define my axis according to the material properties, according to my own previous directions definition.
So, is it possible to modify Global Coordinate System?
Thanks in advance.
May 1, 2019 at 6:48 pm
jpasquerell
Ansys EmployeeIn Mechanical APDL you cannot move the global coordinate system but you can create a local coordinate system and use the TRANSFER command to move your whole model.
May 1, 2019 at 7:26 pm
gorzillon
SubscriberAnd is there any possibility in Ansys Workbench?
May 3, 2019 at 2:08 am
sathya
SubscriberHi You cannot delete global cs in apdl/wb.
Instead you have to create a local cs as per your request (location and type). -
May 28, 2020 at 11:13 am
EngyRashed
SubscriberDid you solve your problem ? if yes .... How?
I have the same problem here
June 29, 2023 at 10:13 pm
Oluwatuyi Johnson
Subscriberwere you able to solve this problems?
June 29, 2023 at 10:11 pm
Oluwatuyi Johnson
SubscriberDid anyone was able to solve this problems?
- The topic ‘Modify Global Coordinate Sysetm’ is closed to new replies.
