TAGGED: diffusion, fluent-uds-udf, governing-equations, permeability
December 6, 2023 at 12:48 pm
Tino Damian
SubscriberHello!
I am new to Ansys Fluent and I have a question regarding UDFs and UDSs.
I'd like to model a special case of diffusion governed by non-conventional equations, provided below.
The first equation is the diffusion equation and well known.
The second equation is an alterted version of Ficks's first law, including a term taking the conformational changes of a material the species diffuses through into account.Â
The third equation describes the time-evolution of the material's changes.
All variables will be scalars as I will model the diffusion only in 1-D.
As far as I can tell, simple cases of Fickian diffusion are modelled analogously via heat conduction.
I would like to know if it is even possible to adapt the default equations and add necessary ones to include the full model I want to implement, via UDFs and UDSs.
If so, which UDFs would I need to use?
Thanks in advance,
Tino
December 6, 2023 at 1:43 pm
Forum ModeratorPossible, yes. Easy, very definitely not. You'll probably need to use User Defined Scalars and write the diffusion model but it's not a project I'd even consider as a relatively new user. Ansys staff are also very limited in what advice we can offer, and UDFs are generally beyond where we can help.Â
December 6, 2023 at 2:42 pm
Tino Damian
SubscriberHey Rob,
thanks for the quick answer! I'll be working my way through the User, Theory and UDF guides and see if it'll be possible for me.
December 6, 2023 at 3:07 pm
Forum ModeratorDon't forget the courses under Learning, left upper on here.Â
- The topic ‘Modifiying governing equations in Ansys Fluent for a case 2 diffusion model’ is closed to new replies.
