TAGGED: droplet, fluid-flow, moving-boundary, multi-phase-flow
August 5, 2021 at 12:11 pm
tictac
SubscriberHi, I am rather new to Ansys Fluent and I am trying to model a water drop interacting with a rotating surface as well as the air around the rotating surface.
The main aim of this simulation is to study the deformation of the water drop after its collision with the rotating surface.
When I look up for relevant tutorials online, people have only modelled water drop falling on a solid, stationary surface instead of a moving one. Can anyone here enlighten me on how to simulate this? Thank you very much.
August 5, 2021 at 12:44 pmRob
Forum ModeratorMuch the same but you need to move the surface. Which orientation is the surface? Ie is the axis in the direction of gravity?
August 5, 2021 at 2:05 pmtictac
SubscriberThe normal of the surface is parallel to direction of gravity, so the drop of water is falling onto the plate. Also, may I know how should I move the surface (rotation) if I am doing a 2D simulation?
August 5, 2021 at 3:56 pmRob
Forum ModeratorErm, if it's 2d with axi-symmetric you'll be modelling a ring of fluid: you might want to rethink what you're doing.
August 7, 2021 at 2:28 amtictac
SubscriberThis is the video I referred to :
https://www.youtube.com/watch?v=MN2zMoF3NyE
Are you saying that I just have to rotate the enclosure?
August 9, 2021 at 11:06 amRob
Forum ModeratorProbably, although it may be easier to draw a cylinder in the geometry tool.
Viewing 5 reply threads- The topic ‘Modelling water drop on a rotating surface’ is closed to new replies.
3587
1193
1086
1068
952
