September 6, 2018 at 3:20 pm
ItalicBike
SubscriberHi everybody,
I'm trying to model a 100x100 mm sandwich composed by 3 layer:
1. Steel sheet, 3 mm thick
2. Viscoelastic polymer, 1 mm thick
3. Steel sheet, 3 mm thick
I need to evaluate the damping effect of the application of 3 mm thick steel sheet with polymer on the FRF of the 3 mm plate. The surfaces are sticked togheter.
I got the complex modulus G' and loss factor from DMA experimental analysis. I try to follow the help, ANSYS Documentation -> Mech APDL -> Material Reference -> Non Linear Material Properties -> Viscoelasticity, in particular from 4.7.3 paragraph. Unfortunately, i don't see any change on the model results.. Could someone help me?
This is the command (APDL) that I used to define the material. Polymer is the name selection.
mat_num=2
MP, EX, mat_num, 0.5E+05
MP, NUXY, mat_num, 0.49
MP, DENS, mat_num, 1E-09
TB, EXPE, mat_num, 1, 10, GMODULUS
TBTEMP, 22
TBPT, DEFI, 0.1, 70000, 34300, 0
TBPT, DEFI, 0.2, 90000, 53100, 0
TBPT, DEFI, 0.5, 110000, 75900, 0
TBPT, DEFI, 1.0, 150000, 119000, 0Â
TBPT, DEFI, 2.0, 200000, 170000, 0
TBPT, DEFI, 3.0, 225000, 207000, 0Â
TBPT, DEFI, 10, 400000, 396000, 0
TBPT, DEFI, 100, 1700000, 1700000, 0
TBPT, DEFI, 500, 4000000, 3600000, 0Â
TBPT, DEFI, 9000, 20000000, 14000000, 0
TB, PRONY, mat_num, , EXPERIMENTAL
CMSEL, S, Polymer, ELEM
EMODIF, ALL, MAT, 2
ALLSEL
/solu
September 6, 2018 at 4:44 pm
John Doyle
Ansys EmployeeAre you missing a comma on the TB,prony,,, command?
Shouldn't it be:Â "TB,prony,mat_num,,,Experimental" ?
Also, the sample APDL input I am looking at has the commands ordered:
TB,PRONY,1, , ,EXPE
TB,EXPE,1, , ,EMOD
TBPT, ,
September 6, 2018 at 6:04 pm
ItalicBike
Subscriber Hi jjdoyle,
thanks for answering. Yes, I was missing a comme on TB, PRONY, , , command. Now he doesn't give any error, but he's not sensitive to modulus variation. In help documentation descripted in my previous post, it's written:
"Using experimental data to define the complex constitutive model requires elastic constants (defined via MP or by an elastic data table [TB,ELASTIC]). The elastic constants are unused if two sets of complex modulus experimental data are defined. This model also requires an empty Prony data table (TB,PRONY) withÂ
TBOPTÂ = EXPERIMENTAL."
So I have the command:
TBTEMP, 22
To define FREQUENCY, G' , G'', Loss Factor (zero because he want just 2 constant, I think the third is calculated). Why he need the empty prony series? I do not understand. Into the solution information, he write:
***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 PARAMETER MAT_NUM =    2.000000000  Â
 MATERIAL         2    EX  =  50000.00    Â
 MATERIAL         2    NUXY = 0.4900000    Â
 MATERIAL         2    DENS = 0.1000000E-08Â
  Complex elastic constants input with TB,EXPE                                  Â
  WITH A MAXIMUM OF 1 TEMPERATURES AND   0 DATA POINTS
  SHEAR MODULUS OPTION FOR MATERIAL 2
  WITH A MAXIMUM OF 1 TEMPERATURES AND   10 DATA POINTS
 TEMPERATURE TO BE USED FOR THE NEXT TBDAT COMMAND= 22.0000
   TEMPERATURE SPECIFICATION= 1
 POINT INSERTED IN THE EXPE TABLE FOR MATERIAL    2
   X=    0.10000  Y=700000.00000
   X=    0.20000  Y=900000.00000
   X=    0.50000  Y=1100000.00000
   X=    1.00000  Y=1500000.00000
   X=    2.00000  Y=2000000.00000
   X=    3.00000  Y=2250000.00000
   X=   10.00000  Y=4000000.00000
   X=  100.00000  Y=17000000.00000
   X=  500.00000  Y=40000000.00000
   X= 9000.00000  Y=200000000.00000
 SELECT     COMPONENT POLYMER                       Â
 MODIFY ALL SELECTED ELEMENTS TO HAVE MAT =        2
 SELECT ALL ENTITIES OF TYPE= ALL AND BELOW
 ***** ROUTINE COMPLETED ***** CP =        0.469
But no change in the results..
September 7, 2018 at 12:32 pm
John Doyle
Ansys EmployeeThe need for "... empty Prony data table (TB,PRONY) with TBOPT = EXPERIMENTAL." is just the way it was programmed to receive the input data. Â
When you say there is "...no change in the results", what result are you referring to?
I would recommend plotting max amplitude vs frequency. The harmonic viscoelasticity mat'l is intended to enable you to define frequency dependent stiffness and damping, so amplitude vs frequency curve should change as you add more stiffness and/or damping, but perhaps a particular result at a particular location and frequency will not change much or at all or perhaps the damping is too small to make any difference.
Alternatively, as a test, you could also try to define the equivalent the Prony Series alpha and tau values in frequency domain (as a test).
John
September 7, 2018 at 1:07 pm
ItalicBike
SubscriberI'm referring the frequency response graph, acceleration vs. frequency.
Howerer, I think that I solved the problem, now it seems to works, but I don't know if it's good.
jjdoyle, you wrote: "Alternatively, as a test, you could also try to define the equivalent the Prony Series alpha and tau values in frequency domain (as a test)."
But I got only experimental results about G' Modulus and Loss Factor, I don't have the shear vs. time relaxation graph. Considering the experimental data the i got, the command that i used it's the correct procedure?
I want to be sure that the procedure is correct, than i try to change the values!
Thank you very much.
September 8, 2018 at 9:25 am
John Doyle
Ansys EmployeeYou can use our curve fitting tool to calculate alpha and tau from experimental data in frequency domain for use in a prony series expression for harmonic viscoelasticity.  Do you have access to the ANSYS customer portal? There is a KM Solution (#2036139) on the customer portal illustrating how to do this.
September 8, 2018 at 12:53 pm
ItalicBike
SubscriberI don't have the access to customer portal, how can i do it? Could you bring be the solution in another way?
Thank you
A.
September 8, 2018 at 2:01 pm
Sandeep Medikonda
Ansys EmployeeHi,
 Here is the APDL input script to generate the curve fit.Â
fini
/clear
/PREP7
/com,Curve Fitting Experimental Data Written To sample.exp
TBFT,EADD,1,SDEC,sample.exp
TBFT,FCASE,1,NEW,PVHE,test
TBFT,FADD,1,VISCO,PSHEAR,5
TBFT,FADD,1,VISCO,PBULK,NONE
TBFT,FADD,1,VISCO,SHIFT,NONE
TBFT,FCASE,1,FINI
TBFT,SET,1,CASE,test,,1,1
TBFT,SET,1,CASE,test,,2,1
TBFT,SET,1,CASE,test,,3,1e-5
TBFT,SET,1,CASE,test,,4,1
TBFT,SET,1,CASE,test,,5,1e-4
TBFT,SET,1,CASE,test,,6,1
TBFT,SET,1,CASE,test,,7,1e-3
TBFT,SET,1,CASE,test,,8,1
TBFT,SET,1,CASE,test,,9,1e-2
TBFT,SET,1,CASE,test,,10,1
TBFT,SET,1,CASE,test,,11,1e-1
TBFT,SET,1,CASE,test,,comp,pvhe
TBFT,FIX,1,CASE,test,,1,0
TBFT,FIX,1,CASE,test,,2,0
TBFT,FIX,1,CASE,test,,3,1
TBFT,FIX,1,CASE,test,,4,0
TBFT,FIX,1,CASE,test,,5,1
TBFT,FIX,1,CASE,test,,6,0
TBFT,FIX,1,CASE,test,,7,1
TBFT,FIX,1,CASE,test,,8,0
TBFT,FIX,1,CASE,test,,9,1
TBFT,FIX,1,CASE,test,,10,0
TBFT,FIX,1,CASE,test,,11,1
TBFT,SOLVE,1,CASE,test,,0,1000,0,0
TBFT,FSET,1,CASE,test
Which contains a storage and loss modulus vs frequency data and is named as 'sample.exp':
/1,freq
/temp,75
 20 2.19E+04 8.44E+03
 30 2.58E+04 9.26E+03
 40 2.87E+04 9.78E+03
 50 3.09E+04 1.01E+04
 60 3.28E+04 1.05E+04
 70 3.44E+04 1.07E+04
 80 3.56E+04 1.08E+04
 90 3.68E+04 1.09E+04
 100 3.79E+04 1.10E+04
 200 4.44E+04 1.13E+04
 300 4.80E+04 1.14E+04
 400 5.04E+04 1.12E+04
 500 5.17E+04 1.11E+04
 600 5.30E+04 1.09E+04
 700 5.40E+04 1.08E+04
 800 5.49E+04 1.08E+04
 900 5.53E+04 1.06E+04
 1000 5.61E+04 1.06E+04
 2000 5.99E+04 9.84E+03
 3000 6.15E+04 9.31E+03
 4000 6.26E+04 8.97E+03
 5000 6.33E+04 8.75E+03
Note: The values for Tau are still TIME.Â
The values are initialized and fixed based on values inversely proportional to frequency and are fixed.Â
Note: The best curve fit for this particular case is achieved by using an absolute error calculation.
Sandeep
September 10, 2018 at 1:33 pm
ItalicBike
SubscriberThanks for your help, Sandeep.
I wrote into the file sample.exp my experimental data (frequency, storage modulus and loss modulus @22°C) and ran the analysis. 2 questions:
1. In solution information panel, i read "successfully saved the calculated coefficients to ANSYS database 1: test". Where can i find it? I want to plot the graph relative moduli vs. time founded with the curve fitting..
2. In analysis settings, solver control, do i switch on the damped option?
Thanks
Regards. -
September 14, 2018 at 4:13 pm
ItalicBike
SubscriberNobody could help me?
September 14, 2018 at 4:54 pm
John Doyle
Ansys EmployeeAssuming you are in MAPDL, after you read in the curve fitting commands above, (make sure you are in the same directory that the file sample.exp is located in) you can open the curve fitter:
Main Menu=>Preprocessor=>Mat'l Properties=>Matl Models=>Structural=>Nonlinear=>Viscoelastic=>Prony Curve Fitting...
..and from there, choose the Curve fit labeled "test" (there is only one). Then click "Plot" to generate the resulting curve fit.
I cannot answer your second question.
- The topic ‘Modelling visco-elastic material for harmonic response analysis’ is closed to new replies.
5849
.jpg?width=20&crop=0,0,20,20)
