TAGGED: #multiphase_models, fluent, hull, open-channel, ship, transient, turbulence
June 4, 2023 at 8:42 am
Ruben Joosten
SubscriberI'm currently trying to simulate flow past the hull of a boat to calculate the drag coefficient.Â
However, I have a pressure inlet and outlet such that the water level remains the same. However, as you can see in the image the water flows from the inlet and then causes a backflow and doesn't create the free stream flow I would like. How can I change my boundary conditions or setup to ensure I achieve the free stream I would like.ÂSome information on my setup can be found below:-VOF, multiphase (water and air)-Open channel flow, (no wave BC, with wave BC there was no change), implicit body force-K-Omega SST turbulence model.-Hull is fixed (preferably want to change it to moving mesh fixed on some axes as a bobbing boat on the water)-Pressure inlet and outlet (Velocity inlet I achieved the same results)-Inlet is set to 1.5m/s at a level 0.25 m (waterline)-Outlet is set to 0.25m,-Wall is no slipIf more information is required, let me know.ÂThank you for taking the time to read my post, -
June 5, 2023 at 3:12 pm
Forum ModeratorIf you look at the domain scale what do you get? Is gravity on?Â
June 6, 2023 at 7:31 pm
Ruben Joosten
SubscriberHello Rob, thank you for responding.
I'm not entirely sure what you mean by domain scale. The domain is of size 10x10x28 m and the boat is 6m.
Gravity is on and is -9.81.Â
June 7, 2023 at 8:38 am
Forum ModeratorOK, and what height is the free surface? You mention putting in 0.25m but is that the middle?Â
- The topic ‘Modelling Ship hydrodynamics, open channel’ is closed to new replies.
