Modelling of laminated glass using shell elements
    • Ave_Nio
      Hello I'm trying to model laminated glass, using shell elements. I was thinking of using a layered shell Glass-PVB-Glass, but I want to capture the deformation of the shell section, that deforms like:
    • ErKo
      Hi
      shell elements will not capture this effect - you would need to model the layers (glass and glue) explicitly using 3D elements (e.g., solid185).
      thank you
      Erik
    • Ave_Nio
      ekostson
      Hi, I feared that might be the case.
      Thank you for the response
    • A7medoo7
      @Ave_Nio
      Did you get a reasonable result?
  • The topic ‘Modelling of laminated glass using shell elements’ is closed to new replies.
