March 14, 2024 at 7:20 pm
Satish Paudel
SubscriberDear all,
I am currently using LSDYNA to model for the masonry structures. It has several parts (brick elements) so need to define the contact within. I would prefer Tiebreak contact algorithms as I would like to model the failure along the interface of these two parts. Could you tell me the exact input parameters that I should use while defining the tiebreak surface to surface contact. Also, what is the difference between the automatic tiebreak surface to surface and tiebreak surface to surface and which would be better. I have some experience to model the interface strength based on normal and shear interface strength that we can provide in tiebreak surface to surface and the friction coefficient. I could not find the better explanation of the other options like SOFT, PENMAX, do these parameters have effect as well.
March 21, 2024 at 8:05 am
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps: Microsoft PowerPoint - TieBreak [Read-Only] (d3view.com)
Ashish Khemka
- The topic ‘Modelling of contact between two parts in LSDYNA’ is closed to new replies.
6540
1311
