May 12, 2025 at 11:39 am
Aymen
SubscriberI'm trying to model an adhesive joint between a shell (mid-surface with offset = middle) and a solid using Cohesive Zone Modeling (CZM) in Ansys. The mid-surface offset creates a 0.5 mm artificial gap (half the sheet thickness), which disrupts the cohesive behavior, since my CZM has no actual thickness. I need to preserve the shell thickness effect for correct bending, but I still want the CZM to work realistically. How can I define the shell–solid contact so the cohesive behavior activates properly under this condition?
May 13, 2025 at 9:13 am
Ashish Khemka
Forum ModeratorHi,
I assume your query is answered over her: CZM contact setup between solid and shell elements in Mechanical
Ashish Khemka
Ansys Innovation Space
971
863
858
792
