July 26, 2023 at 4:22 am
aboa2000
SubscriberGreetings everyone. I am trying to model a Fluid Filled Storage tank in Ansys Acoustic to determine the system's natural, impulsive and convective frequencies. But I keep getting an error saying the following:
- One or more Contact Regions are connected to Acoustic Physics Regions. To improve the solution, the contact settings may have been overwritten internally. Â Refer to the notes for Acoustics Analysis in the Help System for more details.
- One or more Contact Regions have Contact Shell Face or Target Shell Face set to Program Controlled. This can adversely affect performance when writing the input file. Consider displaying element normals and selecting either Top or Bottom shell face.
- An unknown error occurred during solution. Â Check the Solver Output on the Solution Information object for possible causes.
I am not sure what I am doing wrong. Can anyone assist?
July 27, 2023 at 2:26 pm
dlooman
Ansys EmployeeIt's much better to not use contact between the fluid and the structure. The bodies should share the face between them so contact is not needed. Â
- The topic ‘Modelling of a Fluid Filled Storage tank in Ansys Acoustic’ is closed to new replies.
