Modelling laminate defects (delaminations) with Shell elements + layer offset
    • Robert Mehlig
      I am simulation ultrasonic waves in a CFRP plate. I am comparing (trying to replicate) the simulation results to a dataset by Open Guided Waves [1]. To reduce computing resources I have been using Shell elements and defining layered sections to discretize the laminate layers. This has been producing great results so far, though I have only tried the undamaged scenarios.
      Now to my fist question: in an article [2] I read that:
      "The concept of delamination modelling is the same as in [31]. The
      flat shell is divided into three regions: (I) undelaminated, (II) above
      delamination interface, and (III) below delamination interface. These
      regions are denoted in the cross–section through delamination shown
      in figure 2. In the flat shell, all spectral elements are located at the
      neutral plane. There are two layers of elements at the delamination
      region with zero gap between them. In other words, at the delamination
      are two shell elements on top of each other that have the
      same nodal positions but the nodes are not merged. On the boundary
      of the delamination, the nodes of all shell elements are then
      again merged." [2]
      Any idea how to achieve this? Would it be possible to define two layered sections on the same surface element, splitting the layers into two sections? I tried this but I am having issues with the layered section offset.
      In a handbook for realease 18.2 layered sections (for the quadratic shell element 281) are discussed and it states:
      "Value that locates the node with respect to the default origin (midplane) of the section. Valid only when Location = USER. The offset alters only the reference surface of the shell elements (that is, where the nodes are located). It does not change the physical dimensions of the shell itself; the volume and mass remain constant when an offset is specified." [3]
      i.e. the offset defines the out of plane displacement of the middle of the section...? This doesn't seem to be the case in v231. Since I always have had the offset set to "top" in the hope that the excitation is at the surface I'd like to apply the defects in a similar manner.
      For reference, above is the  Open Guided Waves SHM-plate in ansys.
      The second question is regarding to the offset, how does it work?
      As an example I added one layer of aluminum on top of the defect D22. For all cases the rest of the plate has the offset "top" and the defect has offset "user defined" at:
      0 mm
      +2mm
      -2mm
      I am probably confusing myself, but I cannot figure out what to do to get the top 2mm aluminum layer of the defect to sit on top of the plate, exactly like the 0mm image. These images also show the mesh, I don't know if this is by scale / the proportions fit.
      By my logic, "top" should be the same as "-1mm" but it seems to be inverted...
      Thanks in advance, I hope I was clear enough.
      1. Moll, J.; Kathol, J.; Fritzen, C.-P.; Moix-Bonet, M.; Rennoch, M.; Koerdt, M.; Herrmann, A.; Sause, M.; Bach, M.: Open Guided Waves – Online Platform for Ultrasonic Guided Wave Measurements, Structural Health Monitoring, 2019, vol. 18(5–6), 1903–1914, DOI: 10.1177/1475921718817169
      2. P Kudela et al 2020 Smart Mater. Struct. 29 095010
      3. Ansys handbook SECOFFSET
    • Robert Mehlig
      I didn't specify the geometry: The CFRP plate is 500mm x 500mm x 2mm (xyz). The aluminum disc has radius 10mm and depth 2mm.
    • Robert Mehlig
      Additionally: since I am defining the defect area twice, once in the LS for the whole plate and the second in the LS for the defect area, does this cause a problem? If I define the defect area to include only the aluminum, not the original plate layers, does this cause an contact issue between the CFRP plate and the aluminum disc?
    • Robert Mehlig
      Does anyone have any experience regarding the above?
    • jimawa2986 jimawa2986
      The gym body scan addresses is posture and alignment. It can reveal any postural issues or misalignments that might contribute to discomfort or pain during exercise or daily activities. Armed with this knowledge, individuals can work on correcting these issues through targeted exercises or physical therapy, ultimately enhancing their overall quality of life.gym body scan
    • joypatel joypatel
      Integration Quickbooks Online Accounting Software Usa. Qbis Helps You To Sync Your Data With Quickbooks Online As Well As QuickBooks integration
      24/7 Customer Support Talk to QBIS expert anytime—we are here to help. We are a team of real people who can provide direction and answer any questions you might have. No voicemails and we provide 100% local support.
    • raj patel
    • raj patel
    • joypatel joypatel
      Shopify quickbooks Integration It is a leading cloud-based E-commerce platform designed for small and medium-sized businesses.
    • joypatel joypatel
      Woocommerce Quickbooks Integration is an Open source eCommerce plugin that transforms your WordPress website into a fully featured eCommerce store. You can send your customer and order information from WooCommerce to QuickBooks Online and QuickBooks Desktop.
    • joypatel joypatel
      Integrating OpenCart and QuickBooks with QBIS can be a great way to save time and improve the accuracy of your e-commerce and financial records.
    • Mike Brockhoeft
      The Regal Beagle
      will help solve this issue
Viewing 11 reply threads
  • The topic ‘Modelling laminate defects (delaminations) with Shell elements + layer offset’ is closed to new replies.
