July 19, 2020 at 4:23 am
vsjay3
SubscriberHi Everyone,
As part of my research I'm using Ansys Fluent to model :
1) Heat flow through compacted soil (clay) with an embedded ground heat exchanger
2) Heat flow through compacted soil (clay) without an embedded ground heat exchanger
For both above cases I simply need to obtain the resulting temperature contours. I would only be modelling heat flow through the soil medium and not water flow. Water flow will only occur inside the ground heat exchange pipe.
I am new to Ansys Fluent and apologize if this is a very basic question:
Now, I have the required properties of the compacted soil (Density, thermal conductivity etc.) but I'm not sure if to model the compacted soil medium in Fluent as a "Porous" medium or simply a "Solid" medium.
I've read some papers on similar modelling approaches but I could not find a clear answer to this.
Hence, any advice on the above matter would be much appreciated.Thank you!
January 12, 2022 at 6:47 pm
Amir
SubscriberHello vsjay3,
I am also trying to model the soil and a heat exchanger buried under neath the soil. defining the soil as solid did not give me sensible results and I am trying to model it as a "porous" media.
I was wondering have you figured out how to do it in ansys fluent?
I have read quite a bit of material but did not find answer to my question.
your comments would be appreciated.
January 13, 2022 at 4:45 pm
Forum ModeratorIf there is flow in the soil then it's a porous media. If nothing much is moving use a solid zone. Note, if you then want to use the solar calculator rather than a set heat flux (external wall settings) you may need to model some of the air space above ground.
June 30, 2023 at 10:31 pm
Amir
SubscriberHello,
I was wondering were you able to model soil as porous zone?
- The topic ‘Modelling Heat Flow in soil using Ansys Fluent’ is closed to new replies.
