TAGGED: mechanical, thermal-electric, thermal-resistance
October 20, 2021 at 1:44 pm
m_gonser
SubscriberHey guys,
i am currently modelling the thermal behaviour of a battery cell. Therefore i am using ANSYS Mechanical thermal-electric. I Introduced Joule heat to calculate the heating effects of my terminals and connections. Due to oxidation, there is a oxide layer at the terminal (red lines in picture) producing a ohmic resistance. Now i want to calculate the power loss/ heat generation due to the Ohmic resistance. (Ohmic resistance is measured and a constant value)
As i inserted Joule heating in my model, i cannot create an electric contact conductance.
I thought about adding a very thin solid, adding a heat generation (current^2*ohmic resistance) but then i have an additional joule heating in the solid because of the current flow.
Is there another way to define a heat generation/ contact resistance between two surfaces?
October 27, 2021 at 6:10 pmdlooman
Ansys EmployeeThe joule heat you specified should not prevent you from specifying a thermal contact conductance for contact elements between the two surfaces. The thermal conductance specified for the contact elements will produce the heat produced by the ohmic resistance of the contact.
Viewing 1 reply thread- The topic ‘Modelling Electrical Contact Resistance’ is closed to new replies.
5654
1890
1414
1304
