June 14, 2025 at 9:26 pm
scabo
SubscriberHi
I want to model particle laden flows in a periodic pipe. I have set periodic boundary condition for the fluid as periodic. But i want to use DPM in a periodic fashion. How can i do it? Basically i want to model only a short section of pipe and give periodic boundary conditions to both the flow and the solid particles. How can I do it? Any help is greatly appreciated..thanks
June 16, 2025 at 8:29 am
Forum ModeratorThat should work, https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/flu_ug/flu_ug_sec_periodic.html but with steady particles I'm not sure how you'd introduce them. I assume they're neutrally buoyant?
June 16, 2025 at 12:28 pm
scabo
SubscriberHi, thanks. I read the docu- what does this line mean:Â
Steady particle tracks can be modeled only if the particles have a possibility to leave the domain without generating incomplete trajectories. Can you explain this line? Particles will be changing positions with time rght? I think particles can be introduced throught DPM.
- Also, aftr modelling periodic lengths can we expand the periodic section into a long section in order to see the particle trajectory?
June 16, 2025 at 12:45 pm
Forum ModeratorFirst point - the particles must all leave the domain through a boundary (escape/trap) and not time out somewhere in the middle of the section.Â
No. You can plot repeated section but it's the same section repeated which should include the DPM trajectories. If you want to see the tracks down the long pipe you can try using injection files once the flow has been solved using the periodic flow.Â
June 16, 2025 at 4:28 pm
scabo
SubscriberSO, if i want to model particle deposition on the pipe surface, that is not possible using this periodic BC?Â
June 17, 2025 at 12:37 am
scabo
SubscriberAlso if i inject DPM in a streamwise periodic flow, how will the particles behave? Will the particles also have periodic BC attached to them? Or will the particles behave normally?
June 17, 2025 at 8:20 am
Forum ModeratorParticles will behave normally. Given the particles will settle over time, that's not periodic. You're also not going to pick up any duning effects with DPM, you'll want Eulerian or Rocky for that: I'd favour the latter but neither will be periodic.Â
June 17, 2025 at 2:13 pm
scabo
SubscriberSo, how can i make the particles periodic in Fluent? Is this possible to do?
June 17, 2025 at 2:24 pm
Forum ModeratorI suspect you can't. If you turn off gravity they may leave at much the same position as they enter, but you want to see settling which isn't periodic.Â
June 17, 2025 at 2:31 pm
scabo
SubscriberBut i can make the flow periodic (in a short pipe section) but the particles will behave normally. That is perfectly possible right? Lets say the particles settle (so particle is not periodic) but the flow remains periodic. THis is possible to do right?
June 17, 2025 at 2:36 pm
Forum ModeratorShould be, just be aware of the requirement to not have particles go incomplete.Â
June 17, 2025 at 2:38 pm
scabo
SubscriberBut if the particles do settle, then they will have incomplete trajectories-right? So they must roll on the pipe surface to satisfy the requirement
June 17, 2025 at 2:42 pm
Forum ModeratorPotentially, try it and see what happens.Â
June 17, 2025 at 3:03 pm
scabo
SubscriberYes thanks
3266
1031
1004
859
798
