April 25, 2026 at 12:11 pm
youssef.badran
SubscriberHello,
I would like to simulate a solid-solid reaction. I have a fluidized bed containing two types of particles, A and B. When particle A comes into contact with particle B, they react and produce a gaseous product.Â
Is there a way to model this solid-solid reaction using CFD-DEM (Rocky-Fluent) or an Eulerian-Eulerian approach in Fluent ?
April 27, 2026 at 7:55 am
Forum ModeratorIn E-G yes, but remember Fluent uses a volume fraction approach so it's likely you'll have more reaction than you expect as the phases can diffuse to some extent.Â
In Rocky there are contact models, and I think you can use the APIs to model more effects - one for the Rocky team when they wake up.Â
April 28, 2026 at 11:50 am
Oguzhan
Ansys EmployeeHi, in Rocky, there's "CFD Particle Combustion Module (Beta)" module considering the reaction of coal particles during combustion (Please see Chapter 5 of Rocky Module Manual). If you'd like to simulate a different reaction, you'd need to implement it yourself. You can take a look at the similar source code examples that are provided with the SDK module (e.g. CFD Particle Drying).
