February 26, 2019 at 9:07 am
parco
SubscriberHello Community...
Am trying to model a prestressed concrete sleeper in ansys workbench and planning to use solid65 for concrete and link180 for rebar. Since am new to ansys I've started with a simple prestressed beam and through following tutorials been able to model an RC beam but stranded on how to apply prestressing to the rebar in workbench. Am requesting for your assistance on the above and any tutorials shared will be highly appreaciated.
Thanks...
Francis Wantono
February 26, 2019 at 9:16 am
jj77
SubscriberI would try and use the Loads/Bolt Pretension on the lines bodies that will be truss/link elements.
February 26, 2019 at 9:56 am
parco
SubscriberMeaning I apply a prestressing force on the line elements as a component force and then the vertical force on the model in the same step.
February 26, 2019 at 10:13 am
jj77
SubscriberWell I would apply the bolt/pretension first on the rebar/line bodies, and then apply any other loads.
Applying an initial strain via commands (inistate command) might also be a better way.
See this post:
/forum/forums/topic/confirming-prestress-initial-strain-in-link180/
Also the link8 element has a prestrain that can be assigned (never used any of these though, and also link8 are not supported so I would not look into that - use link180 with instate for pre strain).
February 26, 2019 at 12:13 pm
parco
SubscriberI,ve gone through the discussion in the link above. I have a prestressing force of 24kN, how can I relate this to the inistate command and maybe would be glad if you shed more light on the command. I would like to try out both methods that you've proposed.
February 26, 2019 at 12:50 pm
jj77
SubscriberNever used it, but in the help manual there is plenty of info.
Open help and copy and paste this link into the ansys help browser:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_adv/Hlp_G_INSTAPPL.html%23initstressappl
February 26, 2019 at 3:49 pm
peteroznewman
SubscriberDivide the pretension force by the cross-sectional area to get the prestress. Divide that by E to get prestrain. -
February 26, 2019 at 4:49 pm
parco
SubscriberOk...
Thanks for the responses...
Let me try out, and get back to you
February 28, 2019 at 7:57 pm
parco
SubscriberIf am to use the inistate command, am I supposed to insert the command on each line body just like the link180 command
February 28, 2019 at 8:15 pm
February 28, 2019 at 8:24 pm
jj77
SubscriberThe correct way to do it is to use inistate.
not sure, but I would add it on every line body which is link180 converted.
Remember to use the local element system when defining the pre strain or stress, below is an example for your reference only
et,matid,link180
sectype,matid,link
secdata,1 ! cross sec. area (change)
mp,ex,matid,200E9 ! Young's mod. (chnage)
mp.dens,matid,7800 ! dens
INISTATE,SET,CSYS,-2Â Â ! LOCAL ELEMENT SYSTEM FOR PRE-STRAINS
inistate,set,mat,matid ! selects only links with this matid   Â
INISTATE,SET,DTYP,EPELÂ Â ! PRE STRAIN
INISTATE,DEFINE,,,,,1E-7Â Â Â ! STRAIN VALUE (change)
March 1, 2019 at 2:48 pm
parco
SubscriberThanks jj77 for the help...
I'll try this and get back to you
March 4, 2019 at 9:31 am
parco
SubscriberGood day members...
I'm attaching my trial ansys16 workbench file of a sample of RC & Prestressed beam using the inistate sample command provided by jj77.
Please look through and help guide me where I need to improve for my project.
March 4, 2019 at 9:35 am
parco
SubscriberAlso Help with more explanation about the coordinate system in the inistate command.
March 4, 2019 at 9:38 am
parco
SubscriberFor the stress strain data for the solid65 command shown below, does it have to be 35 inputs or I can use any number of inputs.
TB,MISO,MATID,1,35,0
TBTEMP,22
TBPT,,0.0001,2.925
TBPT,,0.0002,5.7
TBPT,,0.0003,8.325
TBPT,,0.0004,10.8
TBPT,,0.0005,13.125
TBPT,,0.0006,15.3
TBPT,,0.0007,17.325
TBPT,,0.0008,19.2
TBPT,,0.0009,20.925
TBPT,,0.001,22.5
TBPT,,0.0011,23.925
TBPT,,0.0012,25.2
TBPT,,0.0013,26.325
TBPT,,0.0014,27.3
TBPT,,0.0015,28.125
TBPT,,0.0016,28.8
TBPT,,0.0017,29.325
TBPT,,0.0018,29.7
TBPT,,0.0019,29.925
TBPT,,0.002,30
TBPT,,0.0021,30
TBPT,,0.0022,30
TBPT,,0.0023,30
TBPT,,0.0024,30
TBPT,,0.0025,30
TBPT,,0.0026,30
TBPT,,0.0027,30
TBPT,,0.0028,30
TBPT,,0.0029,30
TBPT,,0.003,30
TBPT,,0.0031,30
TBPT,,0.0032,30
TBPT,,0.0033,30
TBPT,,0.0034,30
TBPT,,0.0035,30
March 4, 2019 at 10:04 am
jj77
SubscriberThe coordinate system is just the local coordinate system of the element (it is easier to apply there since that is used when applying prestress).
For more info of local coordinate systems for element search the ansys help manual.
March 14, 2019 at 6:51 am
parco
SubscriberHello...
Can you help shed more light on the TBDATA for solid65 command.
Absence of the data table removes the cracking and crushing capability. A value of -1 for constant 3 or 4 also removes the cracking or crushing capability, respectively. If constants 1-4 are input and constants 5-8 are omitted, the latter constants default as discussed in the Mechanical APDL Theory Reference. If any one of Constants 5-8 are input, there are no defaults and all 8 constants must be inpu
Based on the above explanation, what would this mean? I got the command below from a tutorial and I am trying to understand it but am lost some how on the inputs in the command.
TB,CONCR,MATID,1,9
TBTEMP,22
TBDATA,1,1,0.8,1.5,25
March 14, 2019 at 6:57 amparco
SubscriberDoes it mean I input only the first 4 constants and the latter constants default as discussed in the Mechanical APDL Theory Reference.
TB,CONCR,MATID,1,9
TBTEMP,22
TBDATA,1,2,3,4
March 14, 2019 at 8:56 amparco
When I run the solution with this solid65 command, the stress strain points for 60 MPa concrete I get an error
TBTEMP,22
TBPT,,0.0001,3.772
TBPT,,0.0002,7.544
TBPT,,0.0003,11.316
TBPT,,0.0004,15.085
TBPT,,0.0005,18.851
TBPT,,0.0006,22.606
TBPT,,0.0007,26.343
TBPT,,0.0008,30.049
TBPT,,0.0009,33.705
TBPT,,0.001,37.289
TBPT,,0.0011,40.769
TBPT,,0.0012,44.109
TBPT,,0.0013,47.264
TBPT,,0.0014,50.185
TBPT,,0.0015,52.819
TBPT,,0.0016,55.111
TBPT,,0.0017,57.010
TBPT,,0.0018,58.469
TBPT,,0.0019,59.454
TBPT,,0.002,59.943
TBPT,,0.0021,59.932
TBPT,,0.0022,59.433
TBPT,,0.0023,58.476
TBPT,,0.0024,57.108
TBPT,,0.0025,55.383
TBPT,,0.0026,53.367
TBPT,,0.0027,51.125
TBPT,,0.0028,48.724
TBPT,,0.0029,46.224
TBPT,,0.003,43.680
TBPT,,0.0031,41.138
TBPT,,0.0032,38.637
TBPT,,0.0033,36.205
TBPT,,0.0034,33.865
TBPT,,0.0035,31.632
yet with the same command when I use the stress strain points for 30MPa concrete the solution runs
Viewing 18 reply threads- The topic ‘Modeling of a Prestressed Concrete Sleeper’ is closed to new replies.
5894
1306
