January 6, 2023 at 9:52 pm
Amirhosein Heydari
SubscriberHello everyone!
I want to model a rubber ball and the air inside it. So far, I was able to model the hyper elastic material and its internal pressure as a constant pressure. But the problem here is that I want the air pressure inside the ball to increase during the force applied to the ball. When I use air material, it gives an error like below:Â"Air contains invalid property data. These problems are:Â Elasticity is required, but is currently undefined."ÂÂ Does anyone have a solution for this problem? In general, can such a problem be solved in the structural module of Ansys or I have to solve in FSI?ÂI would be very grateful if you could guide me.?? -
January 6, 2023 at 10:25 pm
Hui Liu
Forum ModeratorHi the default Air properties won't work for your application. You can consider using the hydrostatic elements. See this link:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/ans_elem/Hlp_E_HSFLD242.html
- The topic ‘Modeling a plastic ball and compressed air inside it’ is closed to new replies.
Ansys Innovation Space
1283
1117
1068
983
