January 19, 2026 at 1:30 am
Joerg
SubscriberHello, I am modelling a soil column for a seismic analysis. First I run a gravity analysis for 10 sec incl. DR phase, which works fine. After the DR phase there are still some slight oscillations in the first 2sec, after that the model is perfectly still (in equilibrium). When I do a full restart however with the last d3dump, the model blows up. I do not change loading or boundary conditions in the restart deck, the only thing I change is I add the *STRESS_INITITIALIZATION card to tell Dyna its a full restart, extend the termination time to 20 sec, and in the *CONTROL_DR card I set idrflg to -999, since I should not need DR anymore as the equilibrated state should be imported (other than that the restart input is just a copy of the input file of the first run). However, very early on in the analysis the model distorts massively when viewing the d3plot output. The messag file of the restart run does complete, but says that the timestep got very large. The elout file only prints NaN for stress and strains... Hoping somebody can help me find out what is going wrong. (I know I could simply use the dynain file instead of restart, but then I always get these oscillations in the first ~2 sec. They are small, but anyway. I would like to know why the restart does not work...) Thanks
January 19, 2026 at 1:34 am
Joerg
SubscriberI can't seem to be able to post the entire k file here, but these are my control parameters etc (same in both runs):
*KEYWORD*PARAMETER_DUPLICATION2*DATABASE_FORMAT$   iform  ibinary                            unused     0     0*DATABASE_BINARY_D3PLOT$  dt/cycl  lcdt/nr    beam   npltc   psetid    cid    0.1     0     0     0     0     0*DATABASE_BINARY_D3DUMP$  dt/cycl  lcdt/nr    beam   npltc   psetid    cid   nskip     0     8     0     1     0     0     0$   ioopt     3*DEFINE_CURVE$    ID    sidr    sfa    sfo    offa    offo   dattyp  unused1     8     0     0     0     0     0     0     Â$         a1          o1                 unused1         10          10*DATABASE_EXTENT_BINARY$   neiph   neips   maxint   strflg   sigflg   epsflg   rltflg   engflg     0     0     0     11     1     1     0     0$  cmpflg   ieverp   beamip   dcomp    shge   stssz   n3thdt  ialemat     0     0     0     0     0     0     0     0$  nintsld  pkp_sen    sclp   hydro   msscl   therm   intout   nodout     0     0     0     0     2     0*DATABASE_ELOUT$________I_________I_________I_________I_________I_________I_________I_________I$    dt   binary    lcur   ioopt  option1   0.10     3     0     0     1     0*DATABASE_HISTORY_SOLID_SET$    id1    id2    id3    id4    id5    id6    id7    id8    45     44     46     0     0     0     0     0*DATABASE_NODOUT$________I_________I_________I_________I_________I_________I_________I_________I$    dt   binary    lcur   ioopt  option1   0.005     3     0     0     1     0*DATABASE_HISTORY_NODE_SET$    id1    id2    id3    id4    id5    id6    id7    id8    55     54     56     0     0     0     0     0 Â*DATABASE_GLSTAT$    dt   binary    lcur   ioopt   dthff   binhf       unused1   0.02     3     0     0     0     0          0*DATABASE_MATSUM$    dt   binary    lcur   ioopt   dthff   binhf       unused1   0.02     3     0     0     0     0          0*INTERFACE_SPRINGBACK_LSDYNA$   PSID    NSHV   FTYPE     -   FTENSR   NTHHSV   RFLAG  INTSTRN    802     0     0     0     0     0     0     0         Â*CONTROL_TIMESTEP$  dtinit   tssfac    isdo   tslimt   dt2ms    lctm   erode   ms1st     0    0.9     0     0     0     0     1     0$  dt2msf  dt2mslc   imscl                       unused     0     0     0                         Â*CONTROL_CONTACT$  slsfac   rwnpal   islchk   shlthk   penopt   thkchg   orien   enmass     0     0     1     1     1     0     2     0$  usrstr  usrfric   nsbcs   interm   xpene   ssthk    ecdt  tiedprj     0     0     0     0     0     0     0     0$   sfric   dfric    edc    vfc     th   th_sf   pen_sf   unused     0     0     0     0     0     0     0     Â$  ignore   frceng  skiprwg   outseg  spotstp  spotdel  spothin  unused1     0     1     0     1     0     1    0.5     Â$   isym   nserod   rwgaps   rwgdth   rwksf    icov   swradf   ithoff     0     0     0     0     0     0     0     0$  shledg   pstiff   ithcnt   tdcnof   ftall            unused2     1     0     0     0     1               Â*CONTROL_ENERGY$   hgen    rwen   slnten   rylen                  unused     2     2     2     2                    Â*CONTROL_ACCURACY$    osu    inn   pidosu                       unused     0     1     0                         0*CONTROL_BULK_VISCOSITY$    q1     q2    type                       unused    1.5    0.06     1                         Â*CONTROL_SOLID$   esort   fmatrx  niptets   swlocl                  unused     1     0     0     0                    Â$   pm1   pm2   pm3   pm4   pm5   pm6   pm7   pm8   pm9   pm10    0    0    0    0    0    0    0    0    0    0*CONTROL_SHELL$  wrpang   esort   irnxx   istupd   theory    bwc   miter    proj    20     1     -1     0     2     1     1     1$  rotascl   intgrd   lamsht   cstyp6   tshell   nfail1   nfail4  psnfail     0     0     0     0     0     1     1     0$  pstupd   irquad   cntco                       unused     0     0     2                         Â*CONTROL_OUTPUT$   npopt   neecho   nrefup   iaccop   opifs   ipnint   ikedit   iflush     1     0     0     0     0     0     0     0$   iprtf   ierode   tet10   msgmax   ipcurv             unused     0     0     0     0     0               Â*CONTROL_PARALLEL$   ncpu   numrhs   consti    para                  unused     0     0     1     0                    Â*CONTROL_SOLUTION$   soln    nlq   isnan   lcint                  unused     0     0     0    600                    Â*CONTROL_HOURGLASS$    ihq     qh                           unused1     5    0.1*STRESS_INITIALIZATION*CONTROL_TERMINATION$  endtim   endcyc   dtmin   endeng   endmas             unused    20  10000000   0.001     0   100000 -
January 19, 2026 at 1:36 am
Joerg
SubscriberThe model itself I have in separate INCLUDE files (using same for both runs except as explained above)
*INCLUDE01-Geometry.k*INCLUDE01-PART_SECTION.k*INCLUDE01-MAT_207_DR40.k*INCLUDE02-SET.k*INCLUDE03-BOUNDARY.k*INCLUDE03-FF_BOUND.k*INCLUDE03-RIGIDWALL.k*INCLUDE03-toplayer_DOFtied.k*INCLUDE04-PWP_DAMPING.k*INCLUDE05-LOAD_steady.k -
January 22, 2026 at 1:36 am
Joerg
SubscriberSeems like it was a BC issue. Still puzzled why the initial run seemed stable...
5284
1885
1403
1267
