3D Design
3D Design
Model Error-Free But Fails in Fluent
    • 141030
      I currently have a 2022 F1 car model and every repair and prepare task comes up with no errors or issues in the model. However, when the model is inputted into a watertight geometry workflow and tries to create a surface mesh, it comes up with errors and fails. Fluent says to check Diagnostics for any errors but as I stated above, none are appearing. What is going wrong with the model or should I convert it to a facet model before using fluent? Thanks!
    • Luca B.
      Can you also share fluent transcript file or the complete error message.
      Thanks
      Luca
    • 141030
      Hey, unfortunately I lost that file and error message but I remember it containing "can't close face" and "overlapping edge at bn 'x, y' coordinate"
    • Luca B.
      It is not simple to identify the issue. I can suggest you to check again geometry issue using repair tools. Is could be that some hard edges, overlapping surfaces or similar issue are still present and block mesh generation.
      Luca
  • The topic ‘Model Error-Free But Fails in Fluent’ is closed to new replies.
