April 14, 2025 at 5:03 pm
t.tsiris
SubscriberHello,
I have a cyclic symmetric sector where the total number of sectors is 11, which means that the harmonic indices are 0,1,2,3,4,5. I simulate the model to get the first 6 modes for every harmonic index. After that, I want to extract the mode shapes of every mode and harmonic index into a .txt file. I have found a way to do that, through APDL commands into Workbench, by inserting a variable that defines the number of modes that I want to extract. However, I cannot find a way to get the mode shapes of a harmonic index different to 0, since the software recognises that only 6 modes exist. These 6 modes are the first 6 modes with harmonic index=0. I haven't found a command that somehow considers also the harmonic index, so I can extract every possible mode shape.
Is it feasible to get all the mode shapes for every inded though APDL commands or do I need to implement another way?
Thank you in advance.
April 16, 2025 at 7:05 am
Akshay Singh
Ansys Employee-
April 16, 2025 at 8:01 am
t.tsiris
SubscriberHi Akshay,
Thank you for your answer. I know that I can do that. However, I am interested in getting the mode shapes of every mode for every harmonic index, and not just the natural frequencies.
April 16, 2025 at 8:48 am
Akshay Singh
Ansys EmployeeMode shapes can be extracted as images or animations based on your requirement.
April 16, 2025 at 8:51 am
Akshay Singh
Ansys Employeeexamples:
https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/act_script/act_script_examples_export_result_animations.htmlhttps://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/act_script/act_script_examples_export_result_images.html?q=ExportImage()
April 16, 2025 at 11:25 am
Dennis Chen
SubscriberHello, t.tsiris, you can do this through a python script. I’ve written this as part of a project in the past. below is an example script. It just shows the idea, you will want to adjust based on your problems.
model = ExtAPI.DataModel.Project.Model
mesh = model.Mesh
materials = model.Materials
analysis = model.Analyses[1]
solution = analysis.Solution
# with Transaction():
for i in range(1,5): # first 4 modes
sol = solution.AddEquivalentStress()
sol2 = solution.AddTotalDeformation()
sol.CyclicMode = 1
sol.HarmonicIndex = i
sol2.CyclicMode = 1
sol2.HarmonicIndex = i
sol.Name = “Mode_” + str(i) + “_Stress”
sol2.Name = “Mode_” + str(i) + “_Deformation”
mode_start = 1
mode_end = 80
end_index = mode_end
harmonic_index_1 = 9
for j in range(mode_start, end_index, 2): # EO 36
sol.CyclicMode = j
sol.HarmonicIndex = harmonic_index_1
sol2.CyclicMode = j
sol2.HarmonicIndex = harmonic_index_1
sol.Name = “Mode_” + str(j+4) + “_Stress”
sol2.Name = “Mode_” + str(j+4) + “_Deformation”
with Transaction():
solution.EvaluateAllResults()
result_stress = DataModel.GetObjectsByType(DataModelObjectCategory.StressResult)
result_deform = DataModel.GetObjectsByType(DataModelObjectCategory.DeformationResult)
num_stress = 1
for result in result_stress:
result.Activate()
result.Name = “mode” + str(num_stress) + “_stress”
Graphics.ExportImage(“path” + result.Name + “.png”)
# result.ExportToTextFile(“path” + result.Name + “.txt”)
num_stress += 1
num_deform = 1
for result in result_deform:
result.Activate()
result.Name = “mode” + str(num_deform) + “_deformation”
num_deform += 1
April 16, 2025 at 2:56 pm
t.tsiris
SubscriberHi Dennis,
Thanks a lot for your answer. It really helped me a lot!
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
