October 28, 2023 at 1:00 pm
6438189021
SubscriberI wonder what is the mode in Eigenvalue Buckling and how it is essential. The initial number of modes is 2 but my professor told me I must change it to 10. So these are my questions:
- What is mode and how is it important?
- If I analyse 10 modes and the load multiplier is negative from mode 1 to 7 but positive for mode 8 and 9, what does it mean?
- Â
October 28, 2023 at 1:31 pm
peteroznewman
SubscriberThe mode shows you the buckled shape. It is important because it shows you which way the structure moves.
A negative sign on the load multiplier simply means the structure will buckle when the load is applied in the opposite direction.
Sometimes you have no interest in buckling under loads in the opposite direction because that could never happen. In those cases, you can instruct the solver to exclude negative load multipliers. In other cases, you may be interested in the smallest load multiplier both positive and negative.
October 28, 2023 at 1:49 pm
October 28, 2023 at 4:55 pm
peteroznewman
SubscriberThis result shows that the structure will buckle when a load that is 977 times larger than the load applied in Static Structural is applied in the opposite direction.
October 28, 2023 at 5:32 pm
6438189021
Subscriberthank you so much! I will ask next question about vibration in the new post
- The topic ‘Mode in Eigenvalue Buckling’ is closed to new replies.
