July 18, 2024 at 12:54 am
20217579
SubscriberHello, I have been trying to model the mode-II ENF test over the past month but every time I am facing some issues. I have archived my simulation in the link below, I will be very grateful if someone can guide me to what I should do to get this right. Thank you.Â
https://drive.google.com/file/d/1F-qla9hcJ2Y0eXaXktrwTE5GYOT655tZ/view?usp=drive_link
July 23, 2024 at 11:22 am
Ashish Khemka
Forum ModeratorHi,
Ansys employees cannot look into the model but please wait for other forum members to chime in.
Ashish Khemka
July 25, 2024 at 1:56 am
20217579
SubscriberThank you for your reply, I am getting this warning message everytime. I am not sure if this is the reason that the problem persists.Â
*** WARNING *** Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â Â 79.031 Â TIME= 10:49:35
 Fracture parameter calculation issue: crack tip node is attached to   Â
 element type that is not supported, Crack 1, crack tip node 81756,   Â
 element type 170.  The element is ignored.This problem has been discssed in previous threads but the soution proposed there does not work for me as I have generated the pre-crack in ACP-Pre and I can only access that surface through "Pre-Generated interface" options in the contact settings.Â
July 25, 2024 at 11:05 am
Ashish Khemka
Forum ModeratorHello,
Did you refer to the following thread?
The fracture parameters computed during solution may be incorrect (ansys.com)
Ashish Khemka
July 26, 2024 at 1:00 am
September 26, 2024 at 7:00 am
Ashish Khemka
Forum ModeratorHello Abuzar,
My apologies for the delay in response. I will check with the team on the same.
Ashish Khemka
- The topic ‘MODE-II End Notched Flexural simulation using CZM’ is closed to new replies.
5969
1307
