October 23, 2024 at 4:45 am
October 23, 2024 at 1:59 pm
dlooman
Ansys EmployeeRight click on the Total Deformation result in the tree and select Export>Â Export Text File
October 23, 2024 at 2:05 pm
dlooman
Ansys EmployeeThat's not the eigenvector though, just total displacement vs node number. An APDL commands object way would be:Â
/post1Â
set,1,NÂ Â ! N is the mode number
/out,mode_N,txt
prnsol,u Â
!!!! To find file, right click on Solution() and select Open Solver Files Directory
October 24, 2024 at 9:51 am
Vikas Sablaniya
SubscriberI have the experiment's data. I need to determine the EigenVector matrix or Phi Value in order to compute the MAC value (Modal Assurance Criterion).
October 24, 2024 at 2:45 pm
dlooman
Ansys EmployeeWe have the RSTMAC command for that. One of the files can contain the test results in unv format:
Notes
The RSTMAC command allows the comparison of the solutions from either:
Two different results files. Valid only for MAC calculations.
One result file (.rst) and one universal format file (.unv).
5884
1306
