TAGGED: #Modal_Analysis, stiffness, torsional-stiffness
October 17, 2024 at 2:48 am
minia1236
SubscriberAs shown in the attached figure, foundation stiffness was applied to the x, z direction surfaces of the plate and the bottom of the plate with elastic support. And I want to apply rotational stiffness for x, y, z rotation direction. But I can't find related function in ansys modal GUI. I want to know how I can apply rotational stiffness.
October 17, 2024 at 5:57 pm
dlooman
Ansys EmployeeThe elastic supports you have defined will produce a lot of rotational stiffness about the Y axis already. But, if you want to specify a rotational stiffness you could scope a torsional spring to the cylindrical surface at the edge of the hole. You might need to turn on beta features for the torsional spring option to be displayed.Â
October 18, 2024 at 4:02 am
minia1236
SubscriberI found spring-torsional in connections. Thanks for the help.
5799
