mnf file for ADAMS
    • rsekhar1
      I created a unit cube(1mm X 1mm X 1mm) in Workbench. Got a *inp file and opened it in ANSYS Classic. Created the *.mnf file and opened it in ADAMS Flex to check the contents. I am getting junk values for nodal coordinates, nodal masses and stiffness. Can anyone please let me know why this is happening.
      I am using Ansys Workbench 19.2 Mechanical (Its an old workbench product with no limitation on node numbers)
      Attached text file with nodes from Ansys *.inp followed by Ansys *.mnf files.
    • rsekhar1
      Any answers?
      We may not be able to do anything without the files, and ANSYS staff can't download these. Check the dimensions: have you switched from mm to m or similar?
  • The topic ‘mnf file for ADAMS’ is closed to new replies.
