January 18, 2020 at 4:17 pm
DonFelton
SubscriberHey,
Is there a way to include loads (like nodal forces) in the export of an MNF-File?
I try to create the MNF-File in APDL and the goal is to consider the effects of thermal Expansion (stress, strain etc) in the ADAMS-Model.
Since the ADAMS-Macro, which writes the MNF-File, uses the CMS-Substructuring method (Component-Mode-Synthesis), there should be ways to define loads in the "Generation pass" of a superelement, which can be applied to the superelement in the "Use pass".
I'll be thankful for any advice or hint you can think of.
Kind regards,
Jens
Viewing 0 reply threads
- The topic ‘MNF-File export and Load Cases’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1231
1118
1015
