Mixing up of Interfaces and Walls in Ansys Fluent
    • Raj007
    • Keyur Kanade
      You may need to do share topology in DesignModeler or Spaceclaim. nPlease check following videosnDM Share topology:nhttps://www.youtube.com/watch?v=IO4ZtwZdD2InnSpaceClaim Share topology:nhttps://www.youtube.com/watch?v=h43E1YO1LiMnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communitynn
    • Raj007
      Hello,nI have applied shared topology before the start of the simulation. I am afraid that is not the problem.n
    • Keyur Kanade
      Please check if it is successful. nIn meshing, please check if you have only one face at those places.
    • Raj007
      Hello,nI have given shared topology before starting the simulation. I am afraid it is not the problem.nn
      The interfaces mean that the mesh is not connected, or rather is not continuous. Check the geometry so see what is and isn't connected. Which tool are you meshing in? nThe walls are part of the interface:if the interface doesn't fully overlap those walls stop flow escaping from the domain. n
    • Timothée Levionnais
      Hi, I have a similar problem. However, I am doing it with 2 different zones built the exact same way (sharing topology in SpaceClaim, internal boundary condition during the meshing, interfaces created in Fluent afterwards) and one of them is working just fine while the other one doesn't allow the flow to fly through it. When you say that the interface don't fullly overlap, how can we check that it is the case ? Thanks in advance,
      Right click on the interface label in the tree and List. That should return the overlapping area.
Viewing 7 reply threads
  • The topic ‘Mixing up of Interfaces and Walls in Ansys Fluent’ is closed to new replies.
