April 12, 2024 at 8:29 pm
Kevin Gnanaraj
SubscriberHi all,
I am trying to run a simulation in CFX to determine the static thrust of a propeller. I have not been getting results that match experimental data, so I tried to compare FR to stage. However, with the exact same settings on both, I keep getting floating point overflow errors when using the stage interface when compared to FR. What would I need to change to make it work? I want to make this comparison because I will be using valid results to run a coaxial contra-rotating configuration, and frozen rotor will not be ideal for that simulation.
What boundary conditions do I need to add to have a good simulation to get good results? I have tried total pressure, static pressure, velocity for the inlet, and pressure and opening outlets that haven't provided good results. You can see the images here:
April 15, 2024 at 11:42 am
V.P
Ansys EmployeeHi,
Can you check the mesh quality? The mesh quality statistics can be found in the OUT file. Please see if the mesh is OK.
April 15, 2024 at 12:05 pm
Kevin Gnanaraj
SubscriberWhich specific statistics do you want? It was meshed with a target skewness of 0.9
April 15, 2024 at 12:24 pm
V.P
Ansys EmployeeAlso, you can turn on double precision for the run.
April 15, 2024 at 12:28 pm
Kevin Gnanaraj
SubscriberThat was also done, I have asked some people, who have said that my boundary conditions are wrong, I will report back once once simulations with the new conditions are complete.
I was using a symmetry condition and opening pressure of 1 atm and a total pressure of 1 atm, which resulted in little fluid motion.
April 16, 2024 at 8:52 pm
Kevin Gnanaraj
SubscriberMy simulations are even worse, I am getting a force of 1400 N when I expect 45 N. Also, I'm running on a compute cluster, and am trying to run parallel, nd have set a flagÂ
module load ANSYS/2021R1Ânodes="sed -e :a -e N -e 's/\n/,/' -e ta $TMPDIR/mpichnodes"/apps/Common/software/ANSYS/2021R1/v211/CFX/bin/cfx5solve -def default_mesh.def -doubleÂ-par -par-dist $nodes -start-method "HP MPI Distributed Parallel"Âbut I see serial when editing run in progress. What did I write wrong?
- The topic ‘Mixing planes (stage) vs Frozen Rotor in CFX floating point errors’ is closed to new replies.
