August 28, 2024 at 12:47 am
Zeska ZESKA
SubscriberI want to simulate the following problem:I want to study the mixture of two gases, but without combustion. the flows are supersonic and there are a total of three inlets, two of which with oxidizer and one with fuel and the gases are not premixed with the other one. I only know their pressure, which is 6 Pa for oxidizer and 12 Pa for fuel.I have the following procedure:ÂSover: Density-based, Absolute velocity formulation, steady, 2D planar, no gravityEnergy: onViscous model: Spalart-AllmarasSpeices Model: Species Transport (Ractions (volumetic) -uncheked ; Options( diffusions)-uncheked;)      Mixture Properties: Mixture species: air and h2      denisty: ideal-gas      cp- mixing law      thermal conductivity- constant 0.0454      viscosity- constant 1.72e-05     mass diffusivity-constant dilute approx 2.88e-05ÂBoundary conditions:Âinlet air: pressure inlet: gauge tot. press. 600000supersonic/initial gauge press: 600000thermal: 300species: h2: 0Âinlet h2: pressure inlet: gauge tot. press. 1200000supersonic/initial gauge press: 1200000thermal: 290species: h2: 1Âoutlet: gauge pressure: 100000thermal: 300species: h2: 0Âoperating pressure: 0ÂSolution methods:ÂFormulation: implicitFlux-type: roe-fdsSpatial discretization: gradient: least squares cell based     flow: second order upwind     modified turbulent viscoisty: second order upwind     pseudo time method: offÂInitialization: hybrid (no patch)Iterations steps: 10000Âwhen I run the simulation, the residuals go high (higher than e+04) and the simulation stops.Âwhat have I done wrong? What do you thinnk of my procedure? Is it plausible? -
August 28, 2024 at 8:57 am
Forum ModeratorCheck the pressure field after the initialisation process. Also, what stops the mixing region dropping to 100,000 Pa very quickly once it's running? The pressure based coupled solver is good to about 3M so you may not need the Density based solver.Â
August 28, 2024 at 8:18 pm
Zeska ZESKA
SubscriberÂ
Hi RobThank you very much for your reply!I changed the solver to pressure based and the method to Coupled. The rest is completly the same. After initialization I plotted the pressure and density contours and they looked good. The pressure and densityÂat the boundaries show the values ​​that I prescribed.ÂI run the simulation once again for 10000 time steps, but it stoped after around 900 time steps and it said that the solution converged. Do you think that's ok/normal?Moreover, when I plot the final pressure contour, the values at the boundaries are not the one that I had at the begging, but values that are slightly lower, like 1 or 2 bar lower. What causes that?ÂÂÂ
August 29, 2024 at 8:58 am
Forum ModeratorIt shouldn't stop at 900 time steps; 900 iterations is plausible. If you go to Monitors>Advanced you can stop checking convergence and then run on.Â
Re the boundary values. Assuming the solution is converged (not just residual checks) check the mesh and also that you're looking at the correct pressure (static, total etc).Â
