Mixed Mode Bending
    • Jérémy Le Pavic
      I would like to model Mixed Mode Bending experiment.
      When I use inter205 between solid element, the bilinear law give mode I /mode II ratio through C6 (β) parameter.
      Is it possible to use Benzeggah-Kenane law to decribe the mode mixity in Ansys mechanical with CZM element ?
      Best regards,
    • Ashish Khemka
      Please see if this link is of help to you. This article does not use the approach you indicated but may be of interest to you:
      Template LS-DYNA Confernece (ansys.com)
      Ashish Khemka
  • The topic ‘Mixed Mode Bending’ is closed to new replies.
