April 4, 2024 at 2:27 pm
Dato
SubscriberHi,
I have created a rake with 500 number of points whose length is 0.02mm. It's near the wall because I want as many as data near the wall though there may be 2~3 boundary layer growing from the wall. Â
But when I check the xy plot on it, it turns out to be not so many scatter in the graphic.Â
I wonder if Fluent cannot interpolate enough data point in such tiny length? Or I have to go to cfd-post to deal with it? But I think getting row data in Fluent is much more convient and accurate.
Any suggestions would be greatly appreciated.
April 4, 2024 at 4:03 pm
Forum ModeratorHow many cells are there in the near wall region? Did you resolve the mesh to 0.04 microns?Â
April 5, 2024 at 1:44 am
Dato
SubscriberThe rake starts from the surface of the wall and extends perpendicular to the direction of fluid flow. I created the mesh in FluentMeshign and the first boundary layer height is 0.0045mm and the number of layers is 4. I used Last Ratio method. There may be two layer cells in the region.Â
I got that means. But I have tried to do the same thing in cfd-post and I can get as many data as I want in such short length though there are not so many mesh resolved on the line. Could you give some explanations?
regards.
April 5, 2024 at 10:27 am
Forum ModeratorCFD Post uses a different method, and also will interpolate the Fluent data to the nodes from the cell centres. Given the scale and mesh resolution that may mean you see slightly different results.Â
- The topic ‘missing points of rake creating in Fluent’ is closed to new replies.
4597
1505
1386
1209
