March 14, 2024 at 9:40 am
Stemphanie_anansu
Subscriberhi
I am in the process of setting up the combustion of pulverized coal, which involves setting the emissivity and scattering factor of the combustion particles.
The settings were there early on, but I don't know what parameters I adjusted during the process, resulting in no options for these two parameters under material now.
May I ask what equations lead to the setting or not of these two parameters?
March 14, 2024 at 10:05 am
Stemphanie_anansu
SubscriberSupplement:
P1 model is open with missing setup options for these two parameters -
March 14, 2024 at 10:13 am
March 14, 2024 at 10:22 am
Stemphanie_anansu
SubscriberUse the following steps to simply perform the test:
1. active energy
2、active ke
3、active P1
4, active edc and select coal hv volatile air as material
5, active discrete phase, set injection, select combusting particle.
There is no option for these two parameters in the interface under material under combusting particle.
May I know where else I need to set it? Is there any parameter that has been canceled or omitted?
- The topic ‘Missing options for pulverized coal combustion section settings’ is closed to new replies.
5794
