Missing ‘Mesh Regions’ in CFD-POST when using Workbench 2025R1.03
    • idealyoon
      Hello, everyone.
      I recently upgraded my ANSYS installation from 2022R2 to 2025R1.03, completely removing the previous version.
      So far, Designmodeler, Ansys Meshing, CFX, and CFD-Post are all working well. However, i noticed a strange issue in CFD-POST.
      When i open .res file directly through my desktop (Stand-Alone mode) or manually load results in CFD-POST, the 'Mesh Regions' section appears normally in the tree.
      But, when i open the same results via Workbench 2025R1, the 'Mesh Regions' section is completely missing.
      I have already checked Edit -> Options -> Files -> CFX and confirmed "Don't load mesh regions" is unchecked, so that should not be the issue.
      To summarize:
      "Mesh Regions appears in Stand-Alone mode or when i manually load the .res file in CFD-POST."
      "Mesh Regions doe not appear when opening CFD-POST directly from Workbench."
      Is there any way to make Mesh Regions appear automatically when using Workbench 2025R1?
      Any help would be greatly appreciated.
      Best regards.
    • CFD_Friend
      Maybe you have that option turned OFF.
      Open CFD-Post in workbench, go to Edit -> Options -> Files -> CFX
      There under Regions sections, you can find the 'Don't Load Mesh Regions' option.
      Check if that is activated. Deactivate that option to load the mesh regions
      • idealyoon
        Thank you for your response to my question.
        Just to be sure, i tried both checking and un-checking the 'Don't Load Mesh Regions' option as you suggested.
        Unfortunately, there was no change in the behavior even after following your instruction.
        Fortunately, i knew alternative ways to access the 'Mesh Regions' section by manually loading the results in CFD-POST, I will use this method for now.
        If there are any further suggestions or updates, i would be happy to try them.
        Best regards.
