TAGGED: 3d-model, ansys-workbench, faces, missing-part, Share Topology
May 17, 2024 at 9:44 am
AR
SubscriberHello,
I am doing an analysis and to make a better mesh, I have decided to split the body into pieces and use the space claim share topology. However, when I open the model, there are some faces of the part that are not visible. I can select them and then when I do the mesh, they can be seen with the mesh done, but without the mesh, they are not visible.
What's going on? What I can do?
BR
May 17, 2024 at 10:14 am
peteroznewman
SubscriberSee if installing the latest version of the graphics card driver helps.
May 17, 2024 at 11:41 am
AR
SubscriberHello peter
I don't think it's from the graphics. If I combine the parts and set the Share topology option to "none", the part is displayed perfectly.
