3D Design
3D Design
missing face on meshing window
    • avitalmic
      hello!
      im trying to run a simulation on an AVF connection. my arteriovenous model is an STL file which i edited (extruded edges) on spaceclaim and saved as scdoc.
      i imported the file into desigmodeler and when i move to meshing, i face two problems:
      1. i can't mesh the model and get an error
      2. i miss a face from the model
      pics:
    • Keyur Kanade
      the best way to mesh stl is using Fluent Meshing. please check following links.
      https://www.youtube.com/watch?v=S9VGLXOIFZQ
      https://www.youtube.com/watch?v=EZ0ukx3zpJI
      when you import stl in spaceclaim, it will have many faceted faces. if you convert them into geometry faces then each one will convert into one geometry face and it would be mess for meshing.
      if you still want to persist with spaceclaim, please check if you can create geometry out of stl using skin tool or any other tool.
      https://www.youtube.com/watch?v=8SF_IpH74xA
      Keyur
    • avitalmic
      thank you very much Keyur! ill check those links.
      I'd like to understand if the root of the problem is with the fact that the original file is STL, or with the extrude i made in spaceclaim. I ask because first i  only cut the edges of the STL and did manage to run a full simulation in Fluent. after that, i've extrude the edges and the whole mess began.
      also i want to mention that in the first time i converted the model to solid. in the second time i also converted the model to solid but couldnt merge them, so i got 4 parts.
      Avital.
      Delete the mesh. Then mesh the bifurcation (click on it, right click & mesh selected body). Then mesh the extruded sections.
    • avitalmic
      thank you! i'm stil having problem with the missing face. what can i do about it?
    • Keyur Kanade
      you converted facets to solid and then extruded to get more solid bodies. now as the converted solid may not have correct definition, it may fail in extrusion and also may have geometry errors in extrusion. It may face issues in connecting these two solids as well.
      So best way is to create solid from facets with the skin tool and then proceed.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
Viewing 5 reply threads
  • The topic ‘missing face on meshing window’ is closed to new replies.
