February 3, 2024 at 5:41 pm
Andrea Heras
SubscriberHello,Â
I'm running a 2D simulation of a tube with 2 faces, each having a diameter of 15 mm.Â
On one side, there's a volume flow rate of 6x10^-4 m^3/s.Â
On the other side, there's a pressure outlet of 10 Pa.Â
But when I calculate the area, the order of significantly differnt from waht I expected. The are should be 1.5x10^-4 m^2, but the result from ANSYS is 1.5x10^-2 m^2. Can anyone explain why there’s such a large discrepancy?
Additionally, when I applied a scale factor to correct the area, the outlet pressure automatically changed. Instead of remaining at 10 Pa, it increased to 24 Pa. Why did this happen?
Thanks
March 28, 2024 at 2:16 pm
Prashanth
Ansys EmployeeHello: Is it 2D planar or 2D axis symmetric
- The topic ‘Mismatch with area in Ansys Fluent’ is closed to new replies.
5639
1885
1403
1303
