March 23, 2024 at 10:28 am
Andrea Heras
SubscriberHello, Â
I’m running a 2D simulation of a tube with two faces, each having a diameter of 15 mm.
On one side, there’s a volume flow rate of 6×10−4 m^3/s.
On the other side, there’s a pressure outlet of 10 Pa.
However, when I calculate the area, the order of magnitude is significantly different from what I expected. The area should be 1.5×10−4 m^2, but the result from ANSYS is 1.5×10−2 m^2. Can anyone explain why there’s such a large discrepancy?
Additionally, when I applied a scale factor to correct the area, the outlet pressure automatically changed. Instead of remaining at 10 Pa, it increased to 24 Pa. Why did this happen?
ThanksÂ
March 25, 2024 at 11:20 am
Forum ModeratorPlease post images.Â
March 25, 2024 at 8:44 pm
March 26, 2024 at 9:25 am
Forum ModeratorOK, so 15mm height, with an assumed depth of 1m as it's 2d: that looks correct.Â
March 26, 2024 at 9:31 pm
Andrea Heras
SubscriberIs there any way to indicate that it is a 15 mm diameter cylinder and that it is not 1 m deep? Â
April 2, 2024 at 12:29 pm
Forum ModeratorOther than a 3d model?Â
- The topic ‘Mismatch area’ is closed to new replies.
5824
