July 31, 2020 at 2:30 pm
Akismet
SubscriberWhat is the difference between miscible and immiscible fluids?Â
July 31, 2020 at 2:31 pm
prajput
Ansys EmployeeMiscible fluids are fluids that can mix and create what is called an homogeneous mixture. For example air and steam can fully mix.
Immiscible fluids like oil and water cannot mix into each other. Particles of one fluid would keep being separated from the other fluid's particles. Oil and water would form an heterogeneous mixture that are typically called suspensions.
- The topic ‘miscible Vs immiscible fluids’ is closed to new replies.
Ansys Innovation Space
1283
1117
1068
983
