October 8, 2018 at 1:56 pm
October 8, 2018 at 3:08 pm
Sandeep Medikonda
Ansys EmployeeHi Kiran,
 You can still use the mid-surfaces to extract the mid-surface. Are you seeing any errors?
 I would recommend you to use the range option and if you notice any Gaps between the generated surfaces, use the Extend tool along with the Shared Topology option.
 Hope this helps.
Sandeep
Best Practices to post on the Student Community -
October 8, 2018 at 11:23 pm
peteroznewman
SubscriberHi Kiran,
If you are in SpaceClaim, you cannot generate a Midsurface unless the faces have a constant wall thickness. I constructed the wedge below. Note that the Midsurface tool will not select the non-parallel faces.
Another CAD system can create that Midsurface and its FEA model has variable thickness shell elements.
I recommend you keep the part as a solid and mesh with solid elements.
Peter
- The topic ‘Mid surface extraction’ is closed to new replies.
- FSAE CFD – Lesson 1 Preparation question (Using Discovery)
- Add-in Error Excel
- Missing SubDivWrapper.dll
3967
1420
1272
1119
1015
