January 25, 2024 at 11:24 am
Louis Stuart
SubscriberI'm trying to simulate the motion of microrobots (spherical object with ferrous core) through the bloodstream under the influence of a magnetic gradient. Would the MHD module be sutiable for this application or would blood not be classed as conductive enough for this model to be validÂ
January 25, 2024 at 11:37 am
Forum ModeratorDo the microrobots cause the magentic field to change? You might need to calculate the field and then add a body force to the DPM particles (microrobots) if they're very small.Â
January 25, 2024 at 11:46 am
Louis Stuart
SubscriberNo, in this case its assumed they do not effect the magnetic field.Â
January 25, 2024 at 1:15 pm
Forum ModeratorOK, and is the field known? Have a look at https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/flu_udf/flu_udf_DPMDEFINE.html%23flu_udf_sec_define_dpm_body_force for the particle motion part.Â
- The topic ‘MHD module’ is closed to new replies.
