August 24, 2024 at 4:58 am
anindya
SubscriberDear Experts,
I have already created a complex design using FDTD, and now I need to change the axis symmetry (for example: converting the y-axis into the x-axis, z into y, and x into z). Is there a way to do this after the design is completed? Please suggest a solution for this issue.
Thanks and regards,
Anindya Bose
August 26, 2024 at 4:29 pm
Amrita Pati
Ansys EmployeeHi Anindya,
You can change the axis by using the rotation tab of the object, after the design is completed:
If the geometry consists of a large number of sub-components that have to be rotated, then you can group them into a structure group, and then rotate the entire structure group:
Amrita
1313
