June 8, 2020 at 9:59 pmaCamb SubscriberI'm using Fluent to try and rotate two rigid bodies around a fixed point, and I've currently been able to use UDFs to define the rigid body motion and dynamic meshing to account for the mesh movement (see sketch right below for a visual).
 However, as I'm updating the mesh, I notice that the boundary of the fixed center and rotating arm overlap, and this is causing a negative volume error (see image below with a mesh element between the center and arm). I have already tried reducing the timestep, but this hasn't solved the issue completely. Is there a better way to draw my geometry, define my boundaries, update the mesh, etc. such that Fluent knows not to try and mesh between the fixed center and rotating arm?
 Thank you for your help!
- The topic ‘Method to Prevent Mesh Overlap for Rotating Movement’ is closed to new replies.
- affinity not set
                        4167
                        1487
                        1363
                        1194
 You are navigating away from the AIS Discovery experience
