July 10, 2024 at 9:02 am
JooJaehoon
SubscriberHello
I conduct structural analysis applying multi time s.tep
I input different force condition at each time step.
I want to observe stress, strain, deformation result at each time step.
Is there a any method?
July 10, 2024 at 3:50 pm
Aurojyoti Prusty
Ansys EmployeeHello,
I suppose you are doing a static structural problem and applying multiple load at different load step.
After application of load in multistep, add stress, strain, deformation (directional or total) to the solution field and solve the model.Â
Results from each load step (min, max, avg) will be available in each result like graph below (4 steps). Please let us know if this helps or you meant something else in the question.
Thanks,
Aurojyoti
July 11, 2024 at 5:34 am
JooJaehoon
SubscriberHello,
I want to check contour of stress, strain, deformation
- The topic ‘Method to observe analysis result at each time step’ is closed to new replies.
5849
