March 28, 2024 at 9:41 am
anindya
SubscriberDear Experts,
How to add Lithium Niobate Material in the Device (charge) solver database.Is there any specific method of doing this? Kindly suggest a way to execute it.
Thanks and regards,
Anindya Bose
April 1, 2024 at 5:40 pm
Guilin Sun
Ansys EmployeeAs long as you know the materials belongs one of the three categories: insulator, metal and semiconductor, you can create new matgerials in CHARGE:
Semiconductor Material Model Properties
Tips for creating a new semiconductor material
Electrical/Thermal material models in CHARGE, HEAT, and MQWÂ
Thin Film Lithium Niobate Electro-Optic Phase ModulatorÂ
/forum/forums/topic/charge-creating-sio2-semiconductor/Â
metals and insulators have much fewer parameters so you can follow the same procedure to add them.
 Since CHARGE simulates only the semiconductor materials, sometimes you will need to convert insulator/metal to be semiconductor by assign proper semiconductor material properties.
- The topic ‘Method to add Lithium Niobate Material in Lumerical Charge (Device) solver’ is closed to new replies.
