August 8, 2021 at 1:06 am
TAnsys
SubscriberHey!
I'm working on a project to simulate a physical 30m tube (0.5m dia) full of air, with the first 6m filled with premixed 9% Methane before being ignited by spark. This test is to better understand the behaviour of the flame front, pressures and temps over the 30m.
I'm struggling with 2 things.
1: In my physical test, the 6m section is separated by a ballon which is vaporised during the test. I want to fill my simulation in a similar way but whenever I create a split for the different sections it separates the simulation completely, I can't find a way to connect them but have different mixtures.
2: What setup should I use? Ive tried 2D and 3D premixed combustion (have been restricted to the 6m section) and species transport (with a velocity inlet of methane before spark ignition) with no good results.
I'm using fluid flow (fluent).
Any help or advice would be greatly appreciated, thankyou :)
August 9, 2021 at 10:32 amRob
Forum Moderator1) Use Share Topology to connect the two volumes. Or multibody part (DesignModeler).
2) It's going to be very transient, what time step are you using? Why a velocity boundary, or is air & methane supplied after the initial premixed section is ignited?
August 12, 2021 at 3:46 amTAnsys
SubscriberHi Rob, Thanks for your reply.
1) Thankyou this has worked for me connecting the two bodies.
2) Sorry, forget the velocity boundary I was just trying that when I couldn't connect the two mixtures.
I am currently using premixed combustion with spark ignition. The 30m simulation seems to be finished in 0.5 seconds or less, I am using a timestep of 0.001 seconds, for some reason when I reduce the timestep much more than that, the system does not combust, very frustrating haha.
Have you got any pointers for settings or anything else important I may have forgotten?
Thanks again
August 12, 2021 at 9:30 amRob
Forum ModeratorRun double precision.
Viewing 3 reply threads- The topic ‘Methane-air combustion in a 30m tube. Setup help/advice would be greatly appreciated.’ is closed to new replies.
3572
1188
1076
1063
952
