April 15, 2024 at 11:31 am
higino.correia
SubscriberHi,
I´m simulating a metalens and i would like to know how to calculate the optical power in the focal spot and divide it by the transmitted optical power of the lens.
I integrate the poyinting vector in the monitor at the nearfield to know the transmitted power of the lens, i use farfieldexact3d to extrapolate the farfield and get the E^2 across on the focal plane.
how do i get the poyinting vector at the focal plane.Best regards,
João Borlido
April 15, 2024 at 9:45 pm
Guilin Sun
Ansys EmployeeYou can simply integrate the focal sport pwer and the total transmitted power through the Poynting vector. When you use farfieldexact to get E fields at the focal plane, you can also get the H fields so you can calculate the Poynting vector.Â
April 16, 2024 at 10:25 am
higino.correia
SubscriberHi,
Thank you very much for your answer.
Is it possible then to provide a script for calculating the poynting vector from E and H fields at the focal plane?
Best regards.
April 29, 2024 at 7:50 pm
Guilin Sun
Ansys EmployeeSorry to reply you late. Somehow your reply is passed without notification.
First, you need to get H field from farfieldexact https://optics.ansys.com/hc/en-us/articles/360034930733-farfieldexact3d-Script-command by following the example. Once you have the field components, the integration is relatively easy. When it is in the xy plane:
Poyn=Ex*conj(Hy)-Ey*conj(Hx);
Pf=0.5*real(integrate(Poyn,[1:2],x,y);
You may need to pinch some singuletones:Â pinch - Script commandÂ
Please try and let me know if you have questions in scripting.
- The topic ‘Metalens-Optical Power’ is closed to new replies.
5944
1307
