December 3, 2023 at 10:05 pm
Adrián Morgades
SubscriberHello there, I'm trying meshing a prismatic body that consists of six panels made of sandwich honeycomb structures. Aditionally, there are some fittings with their respective screws and washers to join the panels with each other. I'm struggling with the mesh of the body and I don't know if the key of the problem are the contact regions between the different parts. The thing is I'm quite overwhelmed with the countless of contact regions there are. I tried meshing each panel separately by supressing the other panels, but still, ansys fails to mesh. I don't know whether simplifying the model by getting rid of the fittings and screws will still result in an accurate structural analysis or not.Â
Here it is a sneak peak of the interior of the prism with its fittings and screws:
Thanks for the help.
December 5, 2023 at 11:11 am
Aniket Chavan
Forum ModeratorYou can start with the errors you are getting while meshing, as you are seeing contacts, mostly the faces are not shared so there should not be an issue of small imprints, try different methods to mesh and see which one succeeds.
You can right-click on errors, and show problematic geometry to find issues in the model too.
-Aniket
- The topic ‘Meshing with lots of contact regions’ is closed to new replies.
5774
